ACADuser Posted March 22, 2019 Share Posted March 22, 2019 I had all this working in X10 & job as on hold. I started back in X11 & noticed some problems. Not sure if I created them or X11 issues. The wall is on the wrong floor & a doorway will not cut. The file is rather large so I put it in Dropbox. https://www.dropbox.com/s/l6842gxuth79huq/Untitled 1.zip?dl=0 Any advice would be appreciated. Thanks Link to comment Share on other sites More sharing options...
BrownTiger Posted March 22, 2019 Share Posted March 22, 2019 The plan file is missing Link to comment Share on other sites More sharing options...
Mark3D Posted March 22, 2019 Share Posted March 22, 2019 it was there for me just looking at it now Link to comment Share on other sites More sharing options...
BrownTiger Posted March 22, 2019 Share Posted March 22, 2019 5 minutes ago, Mark3D said: it was there for me just looking at it now My bad, you have to click the download button. It only shows jpg on the left.... Link to comment Share on other sites More sharing options...
Mark3D Posted March 22, 2019 Share Posted March 22, 2019 i put a new door opening and it worked Link to comment Share on other sites More sharing options...
ACADuser Posted March 22, 2019 Author Share Posted March 22, 2019 The new doorway worked but how about the first picture ? Link to comment Share on other sites More sharing options...
Mark3D Posted March 22, 2019 Share Posted March 22, 2019 41 minutes ago, ACADuser said: The new doorway worked but how about the first picture ? try changing the floor hieght of the open below area to match the hall at the top of the stairs that seems to fix i think on the 4th floor Link to comment Share on other sites More sharing options...
ACADuser Posted March 22, 2019 Author Share Posted March 22, 2019 Thanks Mark, that did the trick. I don't know how the floor height got changed. Link to comment Share on other sites More sharing options...
ACADuser Posted March 23, 2019 Author Share Posted March 23, 2019 One more issue. The cable railing panel is not showing inside the railing. Link to comment Share on other sites More sharing options...
Mark3D Posted March 24, 2019 Share Posted March 24, 2019 Not sure what is wrong but i just deleted the railing wall and copied one from another area and it worked must be setting some where but could not spot it Link to comment Share on other sites More sharing options...
ACADuser Posted March 24, 2019 Author Share Posted March 24, 2019 Thanks. I'll do that to fix it. This plan was started in X10 and I just started working on it5 again in X11 so I may have done something to the rooms but I think this may be a transition problem from X10. At least the problems are fixable. Link to comment Share on other sites More sharing options...
