builtright3 107 Posted March 22, 2019 Is there an option for obscure glass anywhere for the window schedule? Or do I have to add it to comments? What do you guys suggest because most every bathroom window I put in have obscure and tempered glass. I'm surprised CA doesn't have a check box in the same place you check for tempered and egress. Help would be much appreciated Share this post Link to post Share on other sites
rlackore 403 Posted March 22, 2019 I use the Object Information fields to add this kind of information, generally under the Comment section: Share this post Link to post Share on other sites
builtright3 107 Posted March 22, 2019 7 minutes ago, rlackore said: I use the Object Information fields to add this kind of information, generally under the Comment section: Yes, that is what I'm doing. Just thought I would see if anyone new something I didn't. Thank you for confirming. This is the information I like to see Share this post Link to post Share on other sites
MarkMc 532 Posted March 22, 2019 Make one, alter label to suit and add note in OIP-ADD to library. Then replace from library when needed. Keep in dedicated folder like " _most used" will be at top of user library because of spaces and forward slash Share this post Link to post Share on other sites
builtright3 107 Posted March 22, 2019 Any idea's for best way to label the windows existing or new in the schedule? (E) or (N) Maybe just use the label column or something? Share this post Link to post Share on other sites
builtright3 107 Posted March 22, 2019 I want to end this thread because my question got answered on a different thread. Here is my resolve I didn't know that I could make a custom column in the default schedules under "Custom Objects Field" Not sure if this was new in X11 but I never seen it before Share this post Link to post Share on other sites
MarkMc 532 Posted March 22, 2019 1 hour ago, builtright3 said: Any idea's for best way to label the windows existing or new in the schedule? (E) or (N) Maybe just use the label column or something? I use custom OIP fields for things like this. Often I keep something like this with both options, (N) & (E), somewhere so I only have to delete and set as default for drawing existing, then change and delete set as default for new (or just types since these are shorter than some things I need this for). Like attached. Problem is the COIP fields are global so still working on that. Window exist and other.plan Share this post Link to post Share on other sites
builtright3 107 Posted March 22, 2019 2 hours ago, MarkMc said: I use custom OIP fields for things like this. Often I keep something like this with both options, (N) & (E), somewhere so I only have to delete and set as default for drawing existing, then change and delete set as default for new (or just types since these are shorter than some things I need this for). Like attached. Problem is the COIP fields are global so still working on that. Window exist and other.plan I like it! Thank you that helps! Share this post Link to post Share on other sites
