Gawdzira Posted March 2, 2019 Share Posted March 2, 2019 See attached. That is done with 3 layout boxes carefully placing the 2 on the right which are the bottom of the big schedule. Is there another trick to making the schedules so they conform better to my sheet size? SCHEDULE EXAMPLE TRASH.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted March 3, 2019 Share Posted March 3, 2019 You could reduce the size of your 3D view and that would give more options. I have rotated schedules for layout on 11x17 formatting but you will need to create a rotated layout template page for it to work properly with 3D views which is a bunch of extra work in comparison to fixing the software so it just works like it should. 1 Link to comment Share on other sites More sharing options...
CJSpud Posted March 3, 2019 Share Posted March 3, 2019 I have done it the same way you show it in your PDF file. What Chop is saying is narrow the width of the column with the 3D window views by dragging the column handle with the schedule selected. This will change both the width and the height of the image .... thereby reducing the height of the rows in the schedule as well. You might be able to make your schedule all one piece by doing this saving all the hassle of having to stitch part of the schedule to the schedule title and column headings. Link to comment Share on other sites More sharing options...
