Max3732 Posted February 25, 2019 Share Posted February 25, 2019 I'm using Chief Architect Premier v8. As you can see from the pictures the entry way has multiple ceiling heights as well as stairs that go down from there into a hallway. When I tried to do this I created different rooms for each height, but that created problems down the road. What's the correct approach to a room like this? I'm thinking of starting from scratch and am only focused on doing the interior for figuring out how to furnish it. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 25, 2019 Share Posted February 25, 2019 1 minute ago, Max3732 said: When I tried to do this I created different rooms for each height, but that created problems down the road What problems did it create? Please try to be more specific. Link to comment Share on other sites More sharing options...
Max3732 Posted February 25, 2019 Author Share Posted February 25, 2019 Just now, TheKitchenAbode said: What problems did it create? Please try to be more specific. Instead of having it as one room for changing floor height, walls, etc it created separate zones that all had to be handled separately. It also made it difficult to attach the different rooms together. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 25, 2019 Share Posted February 25, 2019 6 minutes ago, Max3732 said: Instead of having it as one room for changing floor height, walls, etc it created separate zones that all had to be handled separately. It also made it difficult to attach the different rooms together. Rooms are the way to do it but there are two approaches to this. 1.) that higher area is a high room and so you make it high on your first level. or 2.) that higher area is actually a lower room on the first level with another identical room above on the second level that has no floor(open below). I think you would find that latter(2) is likely the better approach. Link to comment Share on other sites More sharing options...
dshall Posted February 25, 2019 Share Posted February 25, 2019 37 minutes ago, TheKitchenAbode said: Rooms are the way to do it but there are two approaches to this. 1.) that higher area is a high room and so you make it high on your first level. or 2.) that higher area is actually a lower room on the first level with another identical room above on the second level that has no floor(open below). I think you would find that latter(2) is likely the better approach. I agree with Graham on this. Do not try to control the ceiling height by defining the ceiling height .... keep all the ceilings at the same height..... and then add a OPEN TO BELOW room above, define it's ceiling height , and that room will control the ceiling height of the room below.... or that room above will have a floor that will control the ceiling of the room below...... much much easier. Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 27, 2019 Share Posted February 27, 2019 On 2/25/2019 at 1:20 PM, TheKitchenAbode said: that higher area is actually a lower room on the first level with another identical room above on the second level that has no floor(open below). That's how I do it. Link to comment Share on other sites More sharing options...
