ChiefToni Posted February 24, 2019 Share Posted February 24, 2019 Hello, I have chief Architect X9 , I can't find the I beams and post for the basement. Can any one explain ? Please Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2019 Share Posted February 24, 2019 Draw a Floor Beam and open up the DBX and convert from default lumber to Steel-I and set the width, depth and elevation. Put some primer on it in 3D and you should be good at least for plan view and a basic 3D display. If you need an accurate cross section you will need to extrude from a p-solid. Place posts manually. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2019 Share Posted February 24, 2019 https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/789 If you want to work with symbols. Link to comment Share on other sites More sharing options...
Electromen Posted February 24, 2019 Share Posted February 24, 2019 Build > Framing > Floor Beam 1 Link to comment Share on other sites More sharing options...
ChiefToni Posted February 27, 2019 Author Share Posted February 27, 2019 On 2/23/2019 at 11:27 PM, Electromen said: Build > Framing > Floor Beam Thank You Link to comment Share on other sites More sharing options...
Kbird1 Posted February 27, 2019 Share Posted February 27, 2019 On 2/23/2019 at 6:52 PM, Chopsaw said: https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/789 If you want to work with symbols. There is also a Library for Steel Columns(Posts) that has been around since X9 https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/1062 M. Link to comment Share on other sites More sharing options...
