Ceiling heights
stager386
Hello!  I am trying to draw this (vaulted?) ceiling with a portion of it at standard height.  I am not sure what to do in regard to ceiling planes and holes.  Any suggestions? Thanks.
The peak of the ceiling is 15' and one side wall is 8'6 and the other 8'9 and the other somewhere in between.  This area over the closet is 8' high. Thank you!
Kate,
If the ridge is centered in the room then you have 2 different sloped roofs to get the 2 different wall heights. Set the roofs up accordingly. The closet can be a separate room with an 8 ft. ceiling or if you have a portion of the room that's 8 ft and not the closet use an invisible wall to define a room and set that height to 8 ft..
