Instacrabb Posted February 15, 2019 Share Posted February 15, 2019 Is there a way to rotate something in Chief from a place other than center? IE- in Vectorworks: I can snap the left side of an object to a point, then I can pivot the entire object from that left point. In Chief, I can only seem to pivot from the center of an object, which makes it incredibly difficult and convoluted to make an object parallel to a wall while staying locked into the corner. In Vectorworks, if I click on the left corner of the object, I can rotate the entire object around that left corner without that corner moving. Same with the right. And if I click the center, it rotates around that point. Apologies if I'm being confusing or asking a question that's already been answered, I've just been searching all day and coming up short. Cheers and thanks, B Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 15, 2019 Share Posted February 15, 2019 Rotate/Resize About Current Point. Do a quick search in the Help files. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted February 15, 2019 Share Posted February 15, 2019 Extend to camera to the point you want to rotate about. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 15, 2019 Share Posted February 15, 2019 Transform and Replicate has Center, Absolute point, and Current Point settings. Link to comment Share on other sites More sharing options...
