Suggestions for method of making apron roof
rockyshepheard
8 minutes ago, rockyshepheard said:
I usually try this extending returns and sometimes it works out ok but I cannot seem to lengthen both sides enough to meet in the middle.
I'm convinced it's not the proper way to do this so I'm asking for alternate recommendations.
Thanks CA genii.
Using the Walls's Roof Return Option set to FULL should work but I have found it a bit Finicky to work with in the past in which case a manual Roof plan should work too.
