FireflyDesigns Posted January 29, 2019 Share Posted January 29, 2019 I'm designing the way I always do and when I go to change a ceiling height in 1 room, it is changing it in every room to match. I've looked at my defaults and reset with no avail. How can I stop this so that I can have varying ceiling heights? Thanks, Jordan X10 Link to comment Share on other sites More sharing options...
madcowscarnival Posted January 29, 2019 Share Posted January 29, 2019 @AlaskanSon replied to this same question I had a bit back. https://chieftalk.chiefarchitect.com/topic/20623-change-height-of-single-room/?tab=comments#comment-167777 I don't know how to quote posts on other threads, but here is what his response had been; it solved the issue I had: "Your problem is that you have an attic room defined over the top of that area. When you change the ceiling height in one room below, Chief thinks that it needs to push the whole floor system up to accommodate the attic floor system...and therefore moves the entire ceiling up. Not sure why you have it there, but one way or another, all you need to do is break that attic room definition and you should be good to go. " 1 Link to comment Share on other sites More sharing options...
lbuttery Posted January 29, 2019 Share Posted January 29, 2019 I don't know how to quote posts on other threads just select-highlite the desired text press Ctrl-c to copy then ctrl-v to paste then select-highlite the text again in the new post and click on B for bold in the post menu Lew Link to comment Share on other sites More sharing options...
FireflyDesigns Posted January 29, 2019 Author Share Posted January 29, 2019 26 minutes ago, madcowscarnival said: Thank you! I think that fixed it. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 29, 2019 Share Posted January 29, 2019 2 hours ago, madcowscarnival said: I don't know how to quote posts on other threads, but here is what his response had been; it solved the issue I had: You can right Click the Post's Time and Date and choose Copy Link , and then paste the link in to a new or existing thread , you can then choose to post it as a Text Link or a Full Quoted HTML Box.(default) Link to comment Share on other sites More sharing options...
