CAD detail lines not responding
RobWhite
I am having difficulty with a CAD detail created from a view. This seems be be concerning regularly. Some of the lines freeze as if the line does not exist. The lines cannot be selected and deleted. These unwanted lines do remain visible on the layout sheet, The only way I have been able to resolve this is be re-creating the CAD detail and starting again. This gets very frustrating and time consuming. Has anyone experienced this and been able to resolve it (Other than starting again.)
I don't think I have attached the detail without attached to whole file.
some thoughts....
some of them maybe Cross-sections lines? which are locked by Default so wouldn't be select-able , unlocking would fix that....
Or
In Layout you can Use the Edit Layout Lines Tool , which should let you select Line work and delete as needed.
