chiefcraft Posted January 22, 2019 Share Posted January 22, 2019 I am having trouble placing an apron front sink into a sink base cabinet. What is the proper procedure? Link to comment Share on other sites More sharing options...
tommy1 Posted January 22, 2019 Share Posted January 22, 2019 I place it in plan and then position it. Make the top portion of the sink base be a blank area. I use a custom countertop to form around the sink. Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2019 Share Posted January 22, 2019 Tommy's method always works. Some farm sinks work with no issue (Most of the Kohlers are OK) Here's if you want or need to do it another way. Note that with both methods you are likely going to need to change the cabinet label (not with the Whitehaven though) Apron Sink.plan 1 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted January 22, 2019 Share Posted January 22, 2019 Love the cabinet schedule with the instructions Mark. Link to comment Share on other sites More sharing options...
CFaasDFCo Posted May 9, 2024 Share Posted May 9, 2024 On 1/22/2019 at 8:08 AM, MarkMc said: Tommy's method always works. Some farm sinks work with no issue (Most of the Kohlers are OK) Here's if you want or need to do it another way. Note that with both methods you are likely going to need to change the cabinet label (not with the Whitehaven though) Apron Sink.plan THIS IS AMAZING!!! I HAVE BEEN FIGHTING THIS FOR SO LONG!!!! THANK YOU THANK YOU THANK YOU Link to comment Share on other sites More sharing options...
