QWConstruction Posted January 4, 2019 Share Posted January 4, 2019 I can only see the bottom corner of the cabinet I'm designing in the specifications - I have always been able to see the full front of the cabinet - wondering if I may have changed something? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 4, 2019 Share Posted January 4, 2019 try the fill window icon Eric has circle or zoom out ( mouse wheel) by the sounds of it you are too close.... M Link to comment Share on other sites More sharing options...
QWConstruction Posted January 4, 2019 Author Share Posted January 4, 2019 This is what I'm seeing and none of the control icons above bring it into view. The only way I can get it into full view is manipulating the mouse pad for several minutes that doesn't always work at all. Link to comment Share on other sites More sharing options...
rlackore Posted January 4, 2019 Share Posted January 4, 2019 Are you experiencing the same problem with the preview pane in other object specification dialog boxes, such as windows, doors, walls, etc? Link to comment Share on other sites More sharing options...
MarkMc Posted January 4, 2019 Share Posted January 4, 2019 22 minutes ago, QWConstruction said: This is what I'm seeing and none of the control icons above bring it into view. The only way I can get it into full view is manipulating the mouse pad for several minutes that doesn't always work at all. At some point your scrolled in Just scroll out and move if needed Link to comment Share on other sites More sharing options...
