TennVol
Crown molding default for rooms?
Searched defaults, the forum and checked help but I can't seem to find a setting or any info on assigning a default crown molding profile as you can with a room baseboard molding. Did I miss something obvious or is there no such setting?
It's a little bit hidden.
Default Settings>Current Floor>Moldings>Selected Profile Specification>Type>select Crown Molding in the drop down box.
You may or may not have to Add ( or replace) a "Selected Profile" in the Molding Profiles area above the one Glenn mentions 1st depending on the Template you started with, some only come with the Baseboard set up by default. Use the dropdown once again as it will only show baseboard 1st off.
You can also change it per Room , in the Room's DBX if the whole Floor doesn't have Crown or Base, uncheck "use Floor default" 1st.
    28310
    nrafiq
    nrafiq
