ShaneK Posted November 30, 2018 Share Posted November 30, 2018 Open plan put default window in and then adjust height in window dbx, it looses its color definition on all walls except front. Yes I re-booted. Saginaw Project 2.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 30, 2018 Share Posted November 30, 2018 No unusual behavior observed in your plan on my PC. DJP Link to comment Share on other sites More sharing options...
ShaneK Posted November 30, 2018 Author Share Posted November 30, 2018 I just started a new plan and it does the same thing, so I either screwed up or bug. Did you put default window in and then change height? You can see what happens to my plans. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 30, 2018 Share Posted November 30, 2018 On 11/30/2018 at 3:59 PM, ShaneK said: Did you put default window in and then change height? Expand Yes, I saw nothing unusual in your plan before or after. DJP 1 Link to comment Share on other sites More sharing options...
Dermot Posted November 30, 2018 Share Posted November 30, 2018 It has to do with your pony walls. Take a look at your windows in an elevation view. If the window is entirely in the upper portion of the wall it will display differently. You can modify how your pony walls and openings display in your Pony Wall Defaults. In particular, you may want to adjust the "Display of Openings in Non-Displayed Parts of Walls". 2 Link to comment Share on other sites More sharing options...
ShaneK Posted November 30, 2018 Author Share Posted November 30, 2018 Thank you Dermot, spot on advice. Link to comment Share on other sites More sharing options...
