para-CAD Posted November 23, 2018 Share Posted November 23, 2018 P-Line solid subtraction issue for me tonight. Suppose to make a timber beam that has an ellipse cut out of the bottom. I could ACTUALLY build it in reality as a framer but in CA I fail. I made a rectangular beam p-line solid. I then made an ellipse the same width. I laid the ellipse over the rectangle and checked the make hole box on the ellipse. Evidently holes can only be cut when completely contained in the other polyline solid. Autocad is much better at this kind of thing in my opinion. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 23, 2018 Share Posted November 23, 2018 An Illustration would help here but it seems that subtraction would not be necessary as you could just draw that in elevation view with a polyline solid. Something like this I am assuming. Link to comment Share on other sites More sharing options...
glennw Posted November 23, 2018 Share Posted November 23, 2018 If you are after something like this. Place two breaks in the bottom edge. Use Change Line/Arc on the centre section. You can use Convert Curve To Polyline if you require a smoother curve. Ah, I just reread your post and noticed you need an ellipse and not a curve - same technique though. Link to comment Share on other sites More sharing options...
para-CAD Posted November 24, 2018 Author Share Posted November 24, 2018 My issue in video format. Thanks for all y'all's help. Polyline_Solid_Subtraction_(HB).m4v Link to comment Share on other sites More sharing options...
para-CAD Posted November 24, 2018 Author Share Posted November 24, 2018 Eric!! You nailed it! In more than one way too. I hadn't thought doorway but that might be the easiest. The client is looking to have grand arching faux stone archways dividing an open timber-framed space. Thanks for the help. Link to comment Share on other sites More sharing options...
