rockyshepheard Posted November 23, 2018 Share Posted November 23, 2018 This newbie is surely creating unclean geometry by doing this but it is a nice quick fix. if you have a roof on floor 1 that is not allowing a complete wall for roof on floor 2 just figure out what roof plane is covering the wall and in the 2D view, make a ‘copy in place’ of the offending plane. Then pull vertices to one side of the blocked section of wall and do just the opposite to the copy. For example, pull vertices south on one and then all north on the other. Of course you must maintain the same shape of the plane while doing this. Can anyone think of a cleaner way to do this? it would be nice if the software could give the option for any wall to pass through any given object so missing walls could be more easily handled. Rocky Link to comment Share on other sites More sharing options...
glennw Posted November 23, 2018 Share Posted November 23, 2018 Rocky, There should be no need to do this. Things should build automatically. I spend a lot of time looking at the plan you posted in another thread and finally gave up looking for a solution. I believe the file was corrupted some how and you would be better to start over and get things to work automatically. 2 Link to comment Share on other sites More sharing options...
MarkMc Posted November 23, 2018 Share Posted November 23, 2018 10 hours ago, rockyshepheard said: Can anyone think of a cleaner way to do this? Shuld be able to solve that either moving the camera or using "stepped cutting plane" Check the reference manual. Link to comment Share on other sites More sharing options...
