Ruby enumerating objects: List Of Rooms, areas or sq ft
BrownTiger
Sometimes it is pretty cool to see total sq of a group of objects, total # of porches, or group together roof planes, or do something with a group.
Since not everyone is a software developer, have time to research Ruby... Here is a simple way to do this:
We want to use array of arrays [or to be exact hashmap of hashmaps] to store the data that will be displayed later.
I use a single global: $tree. The hashmap $tree["rooms"] will be storing rooms and whatever properties you feel are needed.
== To aggregate Rooms for example ==
1) First create a macro called labelRoom to be placed into room label [defaults->Floors and Rooms->Room Label] and lets name it labelRoom
referenced ? obj = referenced : obj = owner
if $tree.nil?
$tree = Hash.new { |hash, key| hash[key] = {} }
end
#id="r" + obj.to_s.gsub('#<NVPublisher:0x000','').gsub('>','') <-- X10
id="r" + obj.object_id.to_s
items = Hash.new()
items['room_name']=obj.name
items['floor_number']=obj.floor_number
items['internal_area']=obj.internal_area
$tree['rooms'][id]=items
2) Create enumeration macro
Macro: showSqft
result=""
$tree["rooms"].keys.each do |key|
result += "Room: " + $tree["rooms"][key]['room_name'] + "[" + $tree["rooms"][key]['floor_number'].to_s + "]" + " \t" + $tree["rooms"][key]["internal_area"].round(0).to_s + " sq ft\n"
end
result
3) Place this macro into a TextEdit
Done
Other times you may want to aggregate nameless objects like roof planes, here is how you can do this.
Macro: labelRoofPlane
if $tree.nil?
end
#id="p" + obj.to_s.gsub('#<NVPublisher:0x000','').gsub('>','') <--X10
id="p" + obj.object_id.to_s
items = Hash.new()
items['roof_plane']=id
items['pitch']=obj.automatic_label
items['area']=obj.surface_area
$tree['roofplanes'][id]=items
s =obj.automatic_label
s
Macro showRoofArea
result=""
sqft=0
$tree["roofplanes"].keys.each_with_index do |key,index|
s= index.to_s
result += "Plane: " + s +"\t" + $tree["roofplanes"][key]['pitch'] + " \t" + $tree["roofplanes"][key]["area"].round(0).to_s + " sq ft\n"
sqft +=$tree["roofplanes"][key]["area"].round(0)
end
result += "Total: " + sqft.to_s + "sq ft\n"
result
Bug fixed in a room name macro (Big Thanks to Alaskan_Son)
  • 6 months later...
Thanks to the original poster for posting this.  I am interested in learning ruby but, I sure have a lot to learn.  As I was trying to use this ruby code in my plan, I could not get the info in the text edit box to populate for more than one roof plane.  It only shows info for roof plane zero.  I must be doing something wrong or overlooking something.
  • 3 weeks later...
Sorry, did not see your post. The code was provided for X10. In x11 new property was offered... obj.object_id.
You need to change this line id="p" + obj.to_s.gsub('#<NVPublisher:0x000','').gsub('>','')
INTO: id ="p" + obj.object_id.to_s
See below
if $tree.nil?
end
items = Hash.new()
s
    32385
    BlissBunny
    BlissBunny
