benchiko1 Posted October 15, 2018 Share Posted October 15, 2018 I have a renovation project that requires the modifying the roof to create more headroom for the attic space used for bedrooms. The existing roof has a 9 1/2:12 pitch. The new roof will have about 6" width of both side with 9 1/2:12 while the new roof will have 3 1/2:12. See attached pictures. Pic2 is what I want to design. The original was a gable. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 15, 2018 Share Posted October 15, 2018 22 minutes ago, benchiko1 said: I have a renovation project that requires the modifying the roof to create more headroom for the attic space used for bedrooms. The existing roof has a 9 1/2:12 pitch. The new roof will have about 6" width of both side with 9 1/2:12 while the new roof will have 3 1/2:12. See attached pictures. Pic2 is what I want to design. The original was a gable. Is it possible to do ? is that what you are asking? yes i think so.... The photos of your Monitor are very hard to see , please use Windows Snipping Tool in Accessories to take Screen Captures instead Also please do you Forum signature , thanks.... Link to comment Share on other sites More sharing options...
DavidJames Posted October 15, 2018 Share Posted October 15, 2018 Something like this? If so, it's fairly easy to do: Create your primary 9/12 pitched roof Use a cad box and convert to hole in roof/ceiling to create your opening for your new roof Manually draw your new 3/12 pitched roof Create extra nodes for the gables Draw gables Use the "Join Roof Planes" command to join gables with roof Link to comment Share on other sites More sharing options...
Kbird1 Posted October 15, 2018 Share Posted October 15, 2018 Easy to do in CA as you can see above...just remember in the Real World you need somewhere for the Water to go off that Corner and a 6" gutter will not do it , you'll end up with a nice Waterfall there, every time it rains otherwise. You might consider not having the Gables and just make it one long Dormer Roof instead .....that way you have a full length gutter and more head Room in the Stairs/Bathroom too. M. Link to comment Share on other sites More sharing options...
BrownTiger Posted October 15, 2018 Share Posted October 15, 2018 I would reiterate what Kbird is saying... Just say No. You literally having 1/2 of the roof diverting all water using this tiny little gutter. This is the design that always damages the window and the door below. My jurisdiction would not even allow such changes. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 15, 2018 Author Share Posted October 15, 2018 Thanks for your response. I've updated my profile to include the signature. What I posted are screen shoot of PDF design I want to recreate in CA. I'm new to CA and working on a renovation to change the attic roof space. I'm having some challenges increasing the height of the wall and creating a different roof slope and wall height. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 15, 2018 Author Share Posted October 15, 2018 Thanks all for your responses. David James can you work me through your suggested solution. Thanks. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 15, 2018 Author Share Posted October 15, 2018 Hope this set of images can help. Thanks. Ben Link to comment Share on other sites More sharing options...
Kbird1 Posted October 15, 2018 Share Posted October 15, 2018 On 10/15/2018 at 12:25 PM, benchiko1 said: Thanks for your response. I've updated my profile to include the signature. What I posted are screen shoot of PDF design I want to recreate in CA. I'm new to CA and working on a renovation to change the attic roof space. I'm having some challenges increasing the height of the wall and creating a different roof slope and wall height. Wall Heights in CA are governed by the Roof/Ceiling Height as a general Rule...... https://www.chiefarchitect.com/support/article/KB-00772/building-a-cape-cod-roof-by-adjusting-ceiling-heights.html ***PS ......in CA you can NOT draw walls etc on the ATTIC Level and get a Room Definition , and CA uses the "Room" to control Heights etc so that is an issue. This Tutorial on Manual Dormers may help you get Started : https://www.chiefarchitect.com/support/article/KB-00449/creating-a-manual-dormer.html there is also a Series of Videos on Dormers : https://www.chiefarchitect.com/search/?default_tab=video&q=dormers this one is specifically Manual Dormers https://www.chiefarchitect.com/videos/watch/9923/focus-manual-dormers.html Mick Link to comment Share on other sites More sharing options...
DavidJames Posted October 16, 2018 Share Posted October 16, 2018 5 hours ago, benchiko1 said: Thanks all for your responses. David James can you work me through your suggested solution. Thanks. Sure. I'll create a walk-through video for you either tonight or tomorrow Link to comment Share on other sites More sharing options...
DavidJames Posted October 18, 2018 Share Posted October 18, 2018 Alright, here's the link to the tutorial on how to achieve that roof style. My apologies in not getting this to you yesterday as promised (YouTube was down). 4 Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2018 Share Posted October 18, 2018 Nicely done DJ. M. Link to comment Share on other sites More sharing options...
DavidJames Posted October 18, 2018 Share Posted October 18, 2018 Thanks, Mick! Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 Thank you very much DJ. I'm try working on it. If I run into any challenges, I'll let you. Once again thank you. Ben Link to comment Share on other sites More sharing options...
DavidJames Posted October 18, 2018 Share Posted October 18, 2018 My pleasure, Ben. Good luck! Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 Hi DJ, I kind of got stuck on the gable. I can't seem to get past that point. See attached my plan and 3D views. Thanks. Attic Space.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2018 Share Posted October 18, 2018 where are you stuck ? your plan does not have a gable? perhaps watch the video again..... as I don't see the Gable Roof planes in your Pic or in the plan.... Mick. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 I'm stuck at the gable. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2018 Share Posted October 18, 2018 5 minutes ago, benchiko1 said: I'm stuck at the gable. You didnt do the 1st step by the look of it ....i.e. draw the two Gable Roof Planes..... look at 2:50 in the video again.... then cut the hole in the Shed Dormer Roof. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 I did. I drew the gables 5' wife each and snapped at 3 points and pulled back the roof plane. Link to comment Share on other sites More sharing options...
DavidJames Posted October 18, 2018 Share Posted October 18, 2018 Ben - the plan you attached doesn't have the gable roofs in it. Just the existing roof and the shed-style. Also, judging by the photo, it looks like you might have drawn the gable roof plane in the wrong direction... Link to comment Share on other sites More sharing options...
Kbird1 Posted October 18, 2018 Share Posted October 18, 2018 8 minutes ago, benchiko1 said: I did. I drew the gables 5' wife each and snapped at 3 points and pulled back the roof plane. You are missing something in the Video.... This is two different things....... one is drawing the two gables , then after that , cut the hole in the existing roof , with the 3 snap points and pull it back in a V. Then you pull the 2 Gable Roof planes back into the V and use the Join Roof Tool to join the Gable Planes to the Exist Shed Dormer Roof Plane FYI : the Plan you posted above does not have any gable roof planes or the V cut into the Dormer Roof..... M. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 Here is how I snapped and pulled back to form the V. The next step "... and use the Join Roof Tool to join the Gable Planes to the Exist Shed Dormer Roof Plane" is what I was not able to do as the 3D does not show me two different roof planes to join. Thanks. Link to comment Share on other sites More sharing options...
benchiko1 Posted October 18, 2018 Author Share Posted October 18, 2018 Here is the 3D view Link to comment Share on other sites More sharing options...
