Flagstone Patio Fill
Sweeney
    30186
    AshleyH
    AshleyH
  • Similar Content
    • By ChiefuserMathews
      Hi, attached is an stair section, How can i turn off the grey fill color for stair?
    • By KTKArch
      (x11) When I open an object to fill (closed polyline etc) I have a standard list and the library option that takes me to Chief's library. It currently only shows that I have patterns of my own making in User Library. It also appears that I can no longer open 3rd party .pat files as I could in earlier versions. And finally, I cannot find a basic EARTH pattern in the defaults. So either I somehow purged some of the patterns or there isn't a default EARTH pattern. And how can I import my earlier .pat files? Not sure if this happened after installing x12 or if it is just this one file. Not using x11 but to finish out this project.
    • By LeeDrafter
      Hi All,
      Is there a way to turn on and off a room fill? Perhaps by layer? I use color fills for all rooms, and I want to be able to print in color without showing the fill in some layer sets.
      Thanks!
    • By rembocanoe66
      I've used CA for years and AutoCAD since 1985. (Yeah I'm old).
      In Florida we do a lot of Block house plans. (CMU) 8x16x8 concrete blocks.
      Other than manually placing block patterns. Does anyone have an easy way to do wall fill patterns to show the ACTUAL CMU BLOCK Pattern in plan view.
      It would be great if it actually placed filled cells required for all window/door openings and corners. Any suggestions?
      Thanks
      Ray
    • By dbritti
      I just downloaded Wayfair's catalog of furniture but I found that when I apply a different fabric texture from the CA library it looks terrible.  It's as if the scaling is WAY out of line. Anyone else have this problem? I really want to use their furniture objects because the CA library is outdated, but they don't behave well.
      Denise Britti
      CA X11
      MacBook Pro
