Joe_Carrick Posted August 26, 2014 Share Posted August 26, 2014 The attached "Doorway" Symbol can be used where you want a Roll-Up Garage Door. It won't show the "Overhead Rectangle" that a Garage Door normally shows, but you can add a CAD Rectangle for that if you need to show the Roll in Plan View. IAE, it displays correctly in 3D, and will be in the Door Schedule if "Doorways" are included in the Schedule. Roll-Up Garage Door.calibz 2 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 26, 2014 Author Share Posted August 26, 2014 You might need to adjust the Symbol's "Y" origin, depending on the wall thickness. I set it to 19" but for a 6" Stud Wall it should be about 20-21". You can play with it as needed. Link to comment Share on other sites More sharing options...
wickedpixel Posted June 5, 2015 Share Posted June 5, 2015 Thank you! Exactly what I was looking for. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 11, 2016 Share Posted February 11, 2016 thanks Joe. Link to comment Share on other sites More sharing options...
evelynf5367 Posted March 16, 2016 Share Posted March 16, 2016 Yes thank YOU Link to comment Share on other sites More sharing options...
Francois Posted March 25, 2016 Share Posted March 25, 2016 Thanks Joe Link to comment Share on other sites More sharing options...
sonnyc Posted April 10, 2016 Share Posted April 10, 2016 I notice that you can show the door opened. Would it be possible to show the door open with just the barrel hood ? Link to comment Share on other sites More sharing options...
JLDrafting Posted April 12, 2016 Share Posted April 12, 2016 Thanks Again Joe. I do Mostly Commercial work and have been using your symbol since you posted it awhile back. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 14, 2016 Author Share Posted April 14, 2016 I notice that you can show the door opened. Would it be possible to show the door open with just the barrel hood ? It would be necessary to create a separate Symbol for that. But you can use the "Delete Surface" Tool to "Open" the door temporarily. That will work for "Standard Render Views" but not for a "Ray Trace". Link to comment Share on other sites More sharing options...
neringa Posted April 26, 2017 Share Posted April 26, 2017 Thank you! Just what I needed! Link to comment Share on other sites More sharing options...
NRST8TRKR Posted May 22, 2017 Share Posted May 22, 2017 Thank you Joe Link to comment Share on other sites More sharing options...
AmritMa Posted August 21, 2017 Share Posted August 21, 2017 Thank you .found what i was looking . Link to comment Share on other sites More sharing options...
