Floating railing
lavorhaynie
I played with it some more and found that selecting the room, (the open below room), gave me a drag handle on the floor bottom.  I drug that handle down to the foundation wall top. This action resolved the issue.
Best regards.
1 hour ago, lavorhaynie said:
How do you get a rail wall to sit on foundation wall below?
Railing room set to open below.
Set structural floor and finish thickness to 0".
Thank you!
Assuming X10 ( your Sig. isn't done yet )     you can now use Pony Walls I believe to place the Railing on top of the retaining Wall structure.
As David said post the Plan as I have no idea how you made the Railing float like that from the pics......
Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too :) ..............
See mine below in Blue for how to do that.
If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too :
UserName> Account > Signatures
