Problem Making Hole In Tha Slab
Aamir77
Folks,
I want to make the ceiling as that of the example picture attached. I have tried to begin with the primitive tools and specifically the cylinder tool but this tool does not possess the option of making the hole in the slab. Please help 26804643_377952549333204_5271048176748292308_n.thumb.jpg.a98ae50b8fdb79b020ac84b8bf5470c2.jpg5b7a4ffcab48e_25sample.thumb.jpg.a0b0b58792db57f7ba310516da450d4e.jpg
Is there a profile in the bottom surface of that Aamir ?
Not sure it can be done with the profile and the offset of center hole in Chief.  But you should be able to come close if you are willing to give up on of the two.
3 minutes ago, Chopsaw said:
You need to build 3 rings - No problem.  What is the shape of the bottom of them ?  Is there a molding or is it flat ?  If if is flat then Psolids will work, if not it will be more involved.
its flat bottom as shown in both the pictures attached herewith (no mouldings). Polyline solid does not work in the circular shape to make a hole in the cylinder. Is there a way out?
