ACADuser Posted July 10, 2018 Share Posted July 10, 2018 Can someone tell me what I am doing wrong with the porch foundation & floor elevation? I want a 4" drop to the floor. I started with mono foundations & changed to stem wall in an attempt to get them to build correctly. But obviously, I have something messed up. The plan was used on another house so I just saved it to a new folder & built the new plan & erased the old plan. When you look at the Ortho Overview you see the foundation build up through the floor. This and other problems plague me on the front & rear porches. So I must be doing something fundamentally wrong. Someone please enlighten me. Thanks Caracas1512.zip Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 10, 2018 Share Posted July 10, 2018 Alan, Go to the foundation and change the stem wall to 8" concrete. Then uncheck "Room provides Floor for Room Above" Or something like that. The Porch Slab should then be correct. 1 Link to comment Share on other sites More sharing options...
dshall Posted July 11, 2018 Share Posted July 11, 2018 Alan, do this..... 1 Link to comment Share on other sites More sharing options...
ACADuser Posted July 11, 2018 Author Share Posted July 11, 2018 That fixed it Scott, can't believe I overlooked the 'C'. I kept trying to change the 'I' & 'G' All this time and I still struggle with foundations. Thanks Link to comment Share on other sites More sharing options...
