Edit names of existing layer sets
Doug_N
Regardless of your toolbar setup, you can get to the Layer Set Management dialog through the menus under Tools->Layer Settings.
I'm not sure if the default toolbar configuration includes the Layer Set Management button but you can always customize your toolbars and add it if it is something that you use frequently.
