Richard_Morrison Posted June 4, 2018 Share Posted June 4, 2018 In drawing the existing conditions of a Victorian, I am trying to figure out how to get the bottom bullnose tread to extend into the entry hall. (Where it extends in reality is shown in red.) But because there is a wall there, the bullnose won't extend into the doorway. Defining the wall as "no room definition" doesn't help. If I move the wall away, the bullnose appears, but that doesn't put the doorway where it needs to be. Any suggestions? (Yeah, 2D CAD may be option.) Link to comment Share on other sites More sharing options...
johnny Posted June 4, 2018 Share Posted June 4, 2018 What about making that first riser a "landing" and shaping it how you want? Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 4, 2018 Author Share Posted June 4, 2018 Thanks, Johnny. I had high hopes for your approach, but it took a large "bite" out of the wall above. Link to comment Share on other sites More sharing options...
VisualDandD Posted June 4, 2018 Share Posted June 4, 2018 Make stairs on their own and convert to symbol and the past in plan?.... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 4, 2018 Share Posted June 4, 2018 Away from my computer but a few options that come to mind (and I’m not sure whether or not the first 2 would work or not)... 1. Try blocking the stairs while the wall is out of the way and then leave them blocked once you put the wall back. 2. Put the stairs onto a different floor and then overlap views in layout or use the reference display. 3. Build that bottom tread with primitives and just make it slightly thicker than the existing tread to help avoid z-fighting. 4. Just build that whole set of stairs with primitives. 5. Depending on the structure you might even consider building the wall with primitives or a symbol. 6. Use Justin’s idea. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 4, 2018 Author Share Posted June 4, 2018 Michael, Just FYI, stairs don't block. I think Justin's idea is the easiest and best-looking, although the bullnose tends to deform slightly when converted to a symbol. Thanks, all, for the ideas! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 4, 2018 Share Posted June 4, 2018 8 minutes ago, Richard_Morrison said: Michael, Just FYI, stairs don't block. Yeah, I was suspecting that might be the case. I couldn’t remember for sure. Oh well, it was worth a shot. Link to comment Share on other sites More sharing options...
