deleting dimensions
WBCdesigner
Just now, WBCdesigner said:
its ok I'll take the answers any way they come! ....But is there a way to select only dimensions using the mouse and holding down a certain key as I drag a box over a area were I want to select dimensions?
Yes.  Switch to a dimension tool and then hold down Control or Shift while you marquis select.
What was meant was to click on the tool bar icon for creating a new dimension string (or whatever hot key you have assigned to create a new dimension string) then hold Shift and do a marquee selection over your entire area where you want to delete the dims. This makes your gross selection specific to the active tool. This will not work for selecting awesome clients. That is a custom tool bar icon not yet available except in metric.
