Post Framing
schrlmbr
When placing a post in my plan, the only part that comes up is the post footing.  The post does not show at all, although defaults indicate a 6x6 should be placed.  Tried this in 2 previous plans and the post placed perfectly.  I did not attach thumbnails as they simply show the post footing, not the post.  Display options are on for framing, post.
Chris Schreier
Chief X6
Are you placing the post under a beam?  Does your plan have terrain?  I think there are times when the program does not have enough room between the beam and the terrain (or floor in some cases) so that it won't create a post and will only create a footing.  This is just a guess based on your statement about it not being a layer issue.  You probably need to post (pun intended) the plan or contact tech if you need more support (pun also intended).
