PB rendering ceiling brightness
Gawdzira
X10 renderings showing the same settings with the exception of the global illumination. The brighter ceiling has no global illumination. The global illumination is a much more attractive look but I can not get the ceiling brighter. I have tried using different backgrounds but nothing is changing it (except a blue sky which gives a blue cast to everything. Any tips.
You could place a few 3D point lights in the room to get some light onto the ceiling and you could also try adding a bit of emissivity to the ceiling finish to brighten it up. There are times when the floor finish/properties can impact on the ceiling as it's settings will effect how much light is reflected off of the floor and bounced to other surfaces.
Maybe make the ceiling a material with some emissivity?
PBR is not quite there yet but I’m excited about where they Chief is going with this approach.
Personally the Srandard rendering serves me well especially since it is updated in layout.
