lbuttery Posted May 4, 2018 Share Posted May 4, 2018 I would like to suppress the room label for one closet while using the MEP layerset I know I can turn off the room label but I would like to show for all other layersets right now it is all or nothing for displaying room labels I am moving my water heater from the crawlspace to the stairwell closet and want to detail it out for the plumber and the room label is in the way I have it off now, but it would be more convenient if there was a way to control this via layersets asking in case I am missing an option or method to control this not a big deal if there isn't Lew Link to comment Share on other sites More sharing options...
MarkMc Posted May 4, 2018 Share Posted May 4, 2018 Copy label, paste, change the layer, open room DBX and uncheck show room label. Label for that room is now on a new layer you can control Link to comment Share on other sites More sharing options...
lbuttery Posted May 4, 2018 Author Share Posted May 4, 2018 Mark: that sorta works except now I have to remember to turn on the "room label - MEP" layer for all the other layersets is there a way to make that new layer on by default for all the other layersets ? all of this will matter when sending various views to layout the "closet" room label only needs to be off for the MEP view(s) Lew Link to comment Share on other sites More sharing options...
Alaskan_Son Posted May 4, 2018 Share Posted May 4, 2018 28 minutes ago, lbuttery said: is there a way to make that new layer on by default for all the other layersets ? Switch to your MEP set, Check "Modify All Layer Sets", turn the layer on, uncheck "Modify All Layer Sets", and turn the layer off. Link to comment Share on other sites More sharing options...
lbuttery Posted May 4, 2018 Author Share Posted May 4, 2018 Michael: thanks, heading out the door will try later tonight Lew Link to comment Share on other sites More sharing options...
