Dryer Vents
I've been trying to find a way to vent a clothes dryer more than 15' (2-90 degree elbows) from an exterior wall.  According to some previous threads it's possible to use an in-line exhaust fan such as "FanTech" to extend the allowable distance.  However, the CRC, IRC or any other code I know of doesn't have such a provision.  The City of San Diego has basically refused to allow any extension of the allowable distance.
Can anyone quote a code section that allows an exception?  Without some sort of solution the location of a Laundry Room is severely restricted in a single family home.
This is a hotly debated issue.  Boosters were allowed for a little while and then removed in 2006 I think it was.  Problem is that the dryer manufacturer has to approve them, the booster has to be listed, and the jurisdiction has to allow
it.  Some have decided to allow them and some have specifically decided to prohibit them.
Anyway, almost every single code has an alternate means exception if you can provide the proper engineering documentation.  That may be a tall order though as dryer manufacturers are unlikely to accept the risks of approving them, so if your jurisdiction doesn’t allow them, you’ll need some pretty costly independent testing and engineering.
Im curious...if anyone knows...what do most laundromats do?  Are they always limited to top floor or end units?
Expand
They use type II dryers, next page of the link I provided
The basic problem with the stated exception is that you can't be sure the same type (capable) dryer will always be installed.  The originally specified dryer may be replaced at some time in the future with one that doesn't comply.  I personally think there should be an exception based on the air-flow (fan assisted if needed).  How do we get this issue fixed in the codes?
