LouFabb Posted April 14, 2018 Share Posted April 14, 2018 Greetings, From the Specialty/Other /Misc library I was able insert a steel I-Beam into my drawing. I can change the width, length and depth of the beam easy enough, but how do I insert drill holes in the steel beam when I'm in plan view. Any suggestions would be appreciated. Thanks in advance, Lou Link to comment Share on other sites More sharing options...
LouFabb Posted April 14, 2018 Author Share Posted April 14, 2018 Thanks solver. Link to comment Share on other sites More sharing options...
ShaneK Posted April 15, 2018 Share Posted April 15, 2018 Eric I like that beam!!!! Anything can be done if you want it bad enough, lol. Link to comment Share on other sites More sharing options...
glennw Posted April 16, 2018 Share Posted April 16, 2018 Build the I-beam using a polysolid and convert it to a Solid. Cut the holes in it using a primitive cylinder and Solid Subtraction. That should take about 2 minutes. 1 1 Link to comment Share on other sites More sharing options...
