srjbb97 Posted April 6, 2018 Share Posted April 6, 2018 Hello!! I am trying to figure out how to adjust the rise angle of a pair of stairs. I have stairs in and they do not reach the next level. Can anyone help me? Also, I have set up the signature but not sure how to get it to show when I post. I am using Chief Architect Premier X9. Link to comment Share on other sites More sharing options...
kMoquin Posted April 6, 2018 Share Posted April 6, 2018 Open the stair dialog box, click "Make Best Fit" Link to comment Share on other sites More sharing options...
srjbb97 Posted April 6, 2018 Author Share Posted April 6, 2018 2 minutes ago, kMoquin said: Open the stair dialog box, click "Make Best Fit" 1 minute ago, solver said: Click the Make Best Fit button. I have tried this and it goes way beyond where I want it to be. I will post pictures in a few. Link to comment Share on other sites More sharing options...
srjbb97 Posted April 6, 2018 Author Share Posted April 6, 2018 The green check mark is where the door opens for the staircase not the one with the red x. First picture is the stairs before the "make best fit" option and the second is a different view of the make best fit. Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 6, 2018 Share Posted April 6, 2018 Now that you have them reaching the next level, select the stairs in the floor plan view, and drag the end to where you want it. It should automatically adjust the threads to fit, but you might not like the result. Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 6, 2018 Share Posted April 6, 2018 You also have tons of control over the rise of the staircase via the tread depth and riser height settings in the stair dialog box. Link to comment Share on other sites More sharing options...
Dermot Posted April 6, 2018 Share Posted April 6, 2018 Make Best Fit will automatically generate enough 11" deep steps to reach the next level that are as close to the "ideal" riser height of 6.75" as the program can get. Looking at your picture, you may not be able to create a stairway that is as short as you want that will reach the next level and still meet typical code requirements. You can either make your tread depth shorter or remove some steps and use a larger riser height. By default, the program will not let you build a stairway with automatic heights unless the riser heights are less then 9". You can turn off the automatic heights and specify whatever riser height you want but your stair may not be very practical or legal. Link to comment Share on other sites More sharing options...
