Larry_Sweeney Posted March 27, 2018 Share Posted March 27, 2018 Is there a "quick fix" for this problem or do you need to see the plan? It's getting quite large and if I don't have to send it I won't. Thank you. Link to comment Share on other sites More sharing options...
ShaneK Posted March 27, 2018 Share Posted March 27, 2018 Post the plan and someone will help. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 27, 2018 Author Share Posted March 27, 2018 The plan isn't as large as I thought it was so I'm sending it "whole". In plan view level 2 I've circled the two areas where I'm not getting the stone material on the end of the wall. Thank you for taking the time. Green_2.zip Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 27, 2018 Author Share Posted March 27, 2018 Eric...................Thank you for your time and advice. Much appreciated. I figured a P-solid would work as a work around. I thought maybe the was a "correct" solution and that I was doing something wrong. Of course that's not to say a good work around isn't correct. Have a great day. Link to comment Share on other sites More sharing options...
dshall Posted March 27, 2018 Share Posted March 27, 2018 I think you are doing something wrong and I think Eric eluded to it. The stone cannot be part of main layer. If it is part of main layer, it cannot wrap around end. I also aligned the pony walls on main layer and for the one wall that did not quite fix.... I FLIPPED THE WALL... I cannot explain but it fixed it. I used no psolids.Pool House & Pavilion 1Fplan FIXED MAYBE BY DSH 1.plan 1 Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted March 27, 2018 Author Share Posted March 27, 2018 Scott...............Thanks for the input. I'm heading out for dinner. I'll look at your plan later or first thing in the morning. Have a great day. Link to comment Share on other sites More sharing options...
