Picture - double vision - STOP
ChiefUserRichK
Use the material selector(Rainbow) click on the pic to open the Define Material properties. In the texture tab you will see Scale, sizing options, select stretch to fit. This will fill the frame with just one iteration but you will need to resize the frame to the proper height to width ratio as your pic.
