Bob-Roraback Posted February 24, 2018 Share Posted February 24, 2018 In previous versions when doing a remodel plan, I was always to put the existing framing on it's own layer and uncheck M to make it not appear in the material list. This function does not seem to be working the same in X10. When I do it to a particular framing member it still appears in the material list. Would someone please try this in X10 to see if they get the same results/ Thank you, Bob Example.zip Link to comment Share on other sites More sharing options...
chief58 Posted February 24, 2018 Share Posted February 24, 2018 In your wall definitions make a wall with no material (air space) for the framing and you shouldn't get anything in your material list Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2018 Share Posted February 24, 2018 You are correct. It's not working correctly. Please file a report with tech support. Link to comment Share on other sites More sharing options...
Bob-Roraback Posted February 24, 2018 Author Share Posted February 24, 2018 Thank you for confirming Michael. I will send a report to tech support, Bob Link to comment Share on other sites More sharing options...
Kbird1 Posted February 24, 2018 Share Posted February 24, 2018 it looks like you are Right..... If you do a Framing overview and click on one of those three joists you will see that the ML is still checked Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2018 Share Posted February 24, 2018 2 minutes ago, Kbird1 said: it looks like you are Right..... If you do a Framing overview and click on one of those three joists you will see that the ML is still checked The Material List setting is Layer Set specific, meaning that you can generate different material lists using different layer sets. The problem is that Chief doesn't currently seem to be respecting that setting for all object types. Link to comment Share on other sites More sharing options...
Kbird1 Posted February 24, 2018 Share Posted February 24, 2018 It doesn't seem in the Default template plan anyway , which I assume this is... , that it is working in any layer-set for framing. I tried it in 3D as well, and just turned off Ceiling Joists as a Test , and they are still in the ML ... it would seem they have broken the ML upgrading it or maybe this is how it is done now? Ie can only turn off assemblies eg a Whole wall , not it's components. M. Link to comment Share on other sites More sharing options...
