Douglas49 Posted February 24, 2018 Share Posted February 24, 2018 Chief X9 Is one able turn textures off in line drawing mode? Regards Doug Link to comment Share on other sites More sharing options...
Kbird1 Posted February 24, 2018 Share Posted February 24, 2018 or the Icon if you add it to the Toolbar ( if not there) Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2018 Share Posted February 24, 2018 Or toggle the “Patterns, 3D” layer and then refresh your view (F5 or Rebuild 3D) Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2018 Share Posted February 24, 2018 ...or delete the lines 1 by 1 in layout. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 24, 2018 Share Posted February 24, 2018 4 minutes ago, Alaskan_Son said: ...or delete the lines 1 by 1 in layout. Are you teaching Architecture at the local prison now Michael ? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 24, 2018 Share Posted February 24, 2018 Just now, Chopsaw said: Are you teaching Architecture at the local prison now Michael ? good way to fill in a Sat. Night maybe? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 24, 2018 Share Posted February 24, 2018 4 minutes ago, Chopsaw said: Are you teaching Architecture at the local prison now Michael ? No, I was just being humorous but also at least partially serious. Sometimes it’s only a handful of lines people really want to get rid of. BTW, you can also adjust material definitions to change the pattern’s line weight/line color or even remove the pattern entirely if it’s just one material that’s causing you problems...and there are several other methods too. Link to comment Share on other sites More sharing options...
Douglas49 Posted February 24, 2018 Author Share Posted February 24, 2018 Thanks for the comments - very helpful Link to comment Share on other sites More sharing options...
rbhomesllc Posted September 15, 2020 Share Posted September 15, 2020 Alaskan_Son Is there a way to change the color or transparency of the pattern lines in Vector View? For example, when I send elevations to layout, the brick and roof pattern lines are so dark... I'd love to have them be very faint and barely show. Right now, I just turn them all off, but would be great to illustrate the patterns of certain materials in vector elevations for construction docs. I have tried changing the colors, but it doesn't look right when I print in Grayscale. I attached elevation drawings that are from Revit that have the look I am after. Notice how the pattern lines are very light gray. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted September 15, 2020 Share Posted September 15, 2020 5 minutes ago, rbhomesllc said: Alaskan_Son Is there a way to change the color or transparency of the pattern lines in Vector View? For example, when I send elevations to layout, the brick and roof pattern lines are so dark... I'd love to have them be very faint and barely show. Right now, I just turn them all off, but would be great to illustrate the patterns of certain materials in vector elevations for construction docs. I have tried changing the colors, but it doesn't look right when I print in Grayscale. I attached elevation drawings that are from Revit that have the look I am after. Notice how the pattern lines are very light gray. See if this helps... 1 Link to comment Share on other sites More sharing options...
