BigKahuna Posted February 22, 2018 Share Posted February 22, 2018 Is there a way for me to change a portion of the exterior metal siding to get a 2 tone look? a darker color on the bottom 2/3 and lighter on the upper 1/3 or so? Link to comment Share on other sites More sharing options...
HumbleChief Posted February 22, 2018 Share Posted February 22, 2018 Pony wall with 2 different materials? Link to comment Share on other sites More sharing options...
BigKahuna Posted February 22, 2018 Author Share Posted February 22, 2018 Thanks , I probably wont rework the plan with a pony wall as its just to show my niece a design option for a new gym I did for her. But I haven't used wall material regions...I will read up on that to see if it is an option ? Link to comment Share on other sites More sharing options...
Kbird1 Posted February 22, 2018 Share Posted February 22, 2018 16 minutes ago, BigKahuna said: Thanks , I probably wont rework the plan with a pony wall as its just to show my niece a design option for a new gym I did for her. But I haven't used wall material regions...I will read up on that to see if it is an option ? I don't think X6 has Material Regions? .............or maybe your signature needs Updating ? So Wall Covering for a Quick View perhaps Link to comment Share on other sites More sharing options...
BigKahuna Posted February 22, 2018 Author Share Posted February 22, 2018 I am using x8 on this model...I upgraded to X9-10 but had some issues trying to open it in later versions. Its only for preliminary design for her to use t sell new memberships, marketing and bank loans etc. Construction docs will be done by her contractor. So I was hoping there might be a simple way to change colors after the fact without too much work. does wall covering work for outside ? If so I might be able to add it then paint it in a different color siding Link to comment Share on other sites More sharing options...
Kbird1 Posted February 22, 2018 Share Posted February 22, 2018 19 minutes ago, solver said: The easy way is using a pony wall. Open the wall, Wall Types, check Pony Wall, select wall type -- make it the same as the upper wall type, set the height and you are done. Should work just assign same wall type to upper and lower...and change the colour or type of siding in one of them.... no different than say have having Stone on the bottom 1/3 or something like that. Perhaps do it in a "Saved As" plan just in case something goes Sideways though.... Link to comment Share on other sites More sharing options...
BigKahuna Posted February 22, 2018 Author Share Posted February 22, 2018 Thanks guys I will try that... Link to comment Share on other sites More sharing options...
