Chrisb222 Posted February 16, 2018 Share Posted February 16, 2018 Hi, Did extensive search, got close but no cigar. Does anyone have, or know the code to produce a macro that would return interior door width as "width-feet / width-inches"? (see attached) Thanks, Chris Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 16, 2018 Author Share Posted February 16, 2018 1 hour ago, solver said: Are you asking about the 2/6 enclosed in the circle? How will you get the value into the circle? The picture is from an older plan where I created that manually with CAD and text. I thought I might use the callout in the schedule to put a macro value in the circle. Right now I'm using the schedule callout with a circle, but it's putting in a number and I would like it to insert the door width instead. Maybe that's not possible... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 16, 2018 Share Posted February 16, 2018 Callout Text is hard-coded to the Schedule Number. It's possible to do a macro for the text, but not in the Callout. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 16, 2018 Share Posted February 16, 2018 Its possible to get the text in a callout too but it would have to be a referenced macro. If you really want the callout then I think your best bet would be to just use the label and add the circle part manually. Here's a quick example... Example for Chris.plan Link to comment Share on other sites More sharing options...
Chrisb222 Posted February 16, 2018 Author Share Posted February 16, 2018 4 hours ago, Alaskan_Son said: Its possible to get the text in a callout too but it would have to be a referenced macro. If you really want the callout then I think your best bet would be to just use the label and add the circle part manually. Here's a quick example... Example for Chris.plan Thanks, but I haven't upgraded to X10 yet. Overall, the Door Schedule Specification DBX seems messed up. In the "Label" tab (?? Is that a Label, or a Label?), if I don't specify a callout for the label, it activates the Height/Width Display options, which are under Label Text (??), but if I DO check to use a callout, the height/width selections, while still active, do nothing, and a non-editable Item Number is placed in the callout... with the option to add leading Label Prefix text. Weird. Somewhat useful, but a strange non-intuitive format, that could be much more useful if you could specify user-defined text or macro in the callout... oh well. Link to comment Share on other sites More sharing options...
