fmrkva9525
Custom cabinet cut sheets?
 Hey guys, i'm a custom woodworker and I use chief architect to design custom  cabinetry and provide customers with a visual reference for our jobs. Most of our work is either custom built-ins, Kitchens, bathroom vanities, etc.  I was wondering if chief has the ability to create cut sheets and build blueprints for the cabinetry? From what I've seen there is not, and if there isn't, is there any software available to upload a chief plan into to create a cut sheet? I'm talking cabinet sides, dados, face frames, etc. (not floor plans, elevations with dimensions, or cabinet schedules) Right now I do all the layouts by hand and it would be nice if I could simply upload a plan file to another program and get the cut sheets made directly from that.
No such feature in Chief, and no export/import to other programs that I know of.
Ah that's what I was afraid of, thanks for the reply tho
8 hours ago, Kbird1 said:
eCabinets has been recommended to me a few times though I am not sure if it integrates with Chief or not?  it is free if you are in the Industry I believe.
http://www.ecabinetsystems.com/
Thank you, I'll check them out
eCabinets does not integrate with Chief.
Here is what it does.  The user creates a "seed" cabinet in each and every type needed for work, and the seeds are all placed in a library file in eCabs.  A seed is not a generic cabinet, but a specific model with features.  Seeds are used to batch up a job file.  Examples of seeds follow.
Base cabinet, one drawer over a L/R double door
Base cabinet, corner with diagonal door, lazy susan inside
Wall cabinet 33 tall, single LH door
Seeds are built using eCabs to a size, but are then resized as required when a job batch is built.  The user has total freedom in building seeds to use just about any type of cabinet construction wanted.  Choose materials, thicknesses, joinery, stretcher arrangement, drawerbox type, hardware, and more.  The eCabinets focus is on CNC-cut parts, but the software can produce cutting sheets for shops operating saws.
In addition to the cutting sheets, eCabinets provides buy lists for hardware, drawerfronts and doors, and drawerboxes.
It takes me a minute or two per line item of a Chief cabinet schedule, to enter it to a batch and perform any necessary editing.  If no editing, and I am only sizing, which is the more typical condition, it only takes seconds.
Thanks for the Followup Gene appreciate it.
M
    28031
    keldhaigh
    keldhaigh
  • Similar Content
    • By birchmore
      I have an octagonal shaped room (silo, 3 stories tall) and I need to build a stair case along the outer wall, following the shape of the octagon, with winders in the corners. What is the best way to go about doing this? I can't seem to figure out how to get the angles correct, the railings to work, get it to create winders on the corners, or get it tight to the wall.
    • By PPRGLLC
      I usually print layouts on 24"x 36" paper so that is what my layout template is set up to do. A client wants to print on 11"x 17". When I change the size of the drawing sheet, it changes the paper size without adjusting the title boxes, notes, etc. Is there a way to resize the entire layout without creating a new layout template for 11" x 17" paper?
    • By HDbyJustin
      The architect I am moonlighting for wants the title sheet to be rotated 90° to the rest of the sheets. I am not sure this is possible without creating a new layout just to have the title sheet be in the correct orientation. Is this an accurate assumption?
    • By edos301
      Hello, I need help creating this specific balaced stair in chief architect premier x12.
      The only thing i could think of was to manually create every step from slabs. I still need to corect some steps from plan view but at least the height and length are good - now how can i add the rails on the inside and outside walls?
      Or maybe is wrongfully thought from the start; what is the simplest, smartest way to create this type of stairs?
    • By kylejmarsh
      Upon sending 3D cameras to layout, I've noticed that they don't come through with the same aspect ratio as shown on my screen. That means I need to zoom waay in to get the view to look correct on the layout. What gives? Is there some setting I'm missing or is this a bug?
      Here you see a screen shot of my camera (exactly as shown, with no toolbars turned on so it's the full CA window) and the view as sent to layout (again, cropped perfectly to show how the camera came through). Next I match the widths and put them side by side to show the difference. What accounts for this? I have been unable to figure it out.
