ChiefRezarel Posted February 3, 2018 Share Posted February 3, 2018 Built at 8:12 roof for the entire house and now want to go back and make the gable wall on the roof over the garage to 10:12 to increase space over the garage. However, the pitch option for the gable wall is grayed out. I noticed in one of the training videos it cited selecting both of the gabled walls before going into the wall specification to change the pitch but in my case this is just a one-off wall on the front of the house being gabled. Is there something I'm missing? Link to comment Share on other sites More sharing options...
tommy1 Posted February 3, 2018 Share Posted February 3, 2018 If it was an auto built roof, did you check "build roof baseline polyline"? If so, that might or could possibly be your problem why you can't change the pitch. I don't recommend checking that unless you know how to use it. Link to comment Share on other sites More sharing options...
chief58 Posted February 3, 2018 Share Posted February 3, 2018 In plan mode just select the roof plan and change the roof pitch there make sure you check the correct ratio button if you want the fasic's to match up the the 8 pitch Link to comment Share on other sites More sharing options...
Kbird1 Posted February 4, 2018 Share Posted February 4, 2018 Gables Walls by Design have no pitch , if you want a 10/12 over the Garage you would change it in the Other two (hip) walls of the Garage , ie N/S if the 2 Gables walls are E/W. Any single wall may have a different Pitch from the Default eg 8/12 in this case. M. Link to comment Share on other sites More sharing options...
