wncbw7 Posted February 1, 2018 Share Posted February 1, 2018 I have a curved stair tower and want to put a curved window in it, is there a way to curve a window in plan view? Not talking about arched tops Also is there a way to make the stairs curved to the wall and not have flat side segmented? curved stair.pdf Link to comment Share on other sites More sharing options...
wncbw7 Posted February 1, 2018 Author Share Posted February 1, 2018 Wow, worked great. I scoured that DBX for a reference to curved can't believe I missed that. Thanks Will fill out signature Link to comment Share on other sites More sharing options...
javatom Posted February 1, 2018 Share Posted February 1, 2018 I would suggest pricing that window before getting to far designing it into the plan. It may never see the light of day with the harsh glow of cost showing on it. Link to comment Share on other sites More sharing options...
wncbw7 Posted February 1, 2018 Author Share Posted February 1, 2018 Javatom, yea am aware of cost, we are probably going to do it in steel and segmented with flat glass. Probably still expensive. Link to comment Share on other sites More sharing options...
glennw Posted February 1, 2018 Share Posted February 1, 2018 8 hours ago, wncbw7 said: Also is there a way to make the stairs curved to the wall and not have flat side segmented? On the General panel of the stair dbx, check Winders. 1 Link to comment Share on other sites More sharing options...
wncbw7 Posted February 3, 2018 Author Share Posted February 3, 2018 Yes I did check winders and they still have segmented sides and handrail. Have also made sure it is tight to the wall Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 3, 2018 Share Posted February 3, 2018 You'll get more productive answers if you post the plan. Link to comment Share on other sites More sharing options...
glennw Posted February 3, 2018 Share Posted February 3, 2018 2 hours ago, wncbw7 said: Yes I did check winders and they still have segmented sides and handrail. Have also made sure it is tight to the wall Yes, the plan would help. Winders will not work unless the stairs are contained within a room. You should be able to control the handrails in the stair dbx. Link to comment Share on other sites More sharing options...
