Spectrum-Design Posted January 24, 2018 Share Posted January 24, 2018 Is there a way to duplicate a layout page? It would be much easier than copying and pasting everything on a page to a new one over and over. For instance - I have two plan files, one for concept A and one for concept B. I'd like to be able to copy the 5 layout pages showing concept A and duplicate them so that I can then just change all the views to concept B 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 24, 2018 Share Posted January 24, 2018 I would just do a save as, and change as needed Link to comment Share on other sites More sharing options...
Spectrum-Design Posted January 24, 2018 Author Share Posted January 24, 2018 That is what I did, though I typically like to keep them all in one layout file than having a different layout file for each option Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 24, 2018 Share Posted January 24, 2018 I use one template plan b/c I too had several for different condition but it got to much to change all of them to keep them up to date. One generic template is good for me and remember you can add anything off the page and drag it on when you need it. That way you have what you need to work more efficient. Anything off the page won't print. Link to comment Share on other sites More sharing options...
wjmdes Posted January 25, 2018 Share Posted January 25, 2018 I set up a rather extensive layout template that has most everything I may need for a project and find it quicker to delete a page or item I do not need rather than add it later. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 25, 2018 Share Posted January 25, 2018 7 hours ago, Spectrum-Design said: Is there a way to duplicate a layout page? It would be much easier than copying and pasting everything on a page to a new one over and over. For instance - I have two plan files, one for concept A and one for concept B. I'd like to be able to copy the 5 layout pages showing concept A and duplicate them so that I can then just change all the views to concept B I understand the desire for a quicker method, but you should be able to make pretty stinkin' quick work of this by inserting 5 pages using either Insert Page Before or Insert Page After. Then, using your Project Browser, go to Page 1, Control+A (Select All), Control+C (Copy), switch to Page 6, Control+Alt+V (Paste Hold Position), and repeat for pages 2-5 and 7-10. I just tested this method out on 5 layout pages and it took just over a minute. Oh ya, I guess I forgot you also need to relink all the appropriate views so maybe another minute or 2 doing that, but that part would be necessary anyway. Link to comment Share on other sites More sharing options...
dshall Posted January 25, 2018 Share Posted January 25, 2018 8 minutes ago, Alaskan_Son said: I understand the desire for a quicker method, but you should be able to make pretty stinkin' quick work of this by inserting 5 pages using either Insert Page Before or Insert Page After. Then, using your Project Browser, go to Page 1, Control+A (Select All), Control+C (Copy), switch to Page 6, Control+Alt+V (Paste Hold Position), and repeat for pages 2-5 and 7-10. I just tested this method out on 5 layout pages and it took just over a minute. Oh ya, I guess I forgot you also need to relink all the appropriate views so maybe another minute or 2 doing that, but that part would be necessary anyway. I think you understand it correctly, the slow down is linking the views to a new plan file. Link to comment Share on other sites More sharing options...
Spectrum-Design Posted January 26, 2018 Author Share Posted January 26, 2018 On 1/24/2018 at 7:38 PM, Alaskan_Son said: I understand the desire for a quicker method, but you should be able to make pretty stinkin' quick work of this by inserting 5 pages using either Insert Page Before or Insert Page After. Then, using your Project Browser, go to Page 1, Control+A (Select All), Control+C (Copy), switch to Page 6, Control+Alt+V (Paste Hold Position), and repeat for pages 2-5 and 7-10. I just tested this method out on 5 layout pages and it took just over a minute. Oh ya, I guess I forgot you also need to relink all the appropriate views so maybe another minute or 2 doing that, but that part would be necessary anyway. This is what I've typically done. I may end up using 2 layout file more often. It is much easier to just change the referenced plan file than it is to relink all the views. Thanks for the input guys! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 26, 2018 Share Posted January 26, 2018 You know what would really be nice? Group select pages in Project Browser>right click>Referenced Files. Couldn’t get much quicker than that. Add in the ability to Copy and paste the selected pages per the original suggestion and we’re really in business. 1 Link to comment Share on other sites More sharing options...
