How do I copy a detail from one page to another, modify it so the original detail remains unchanged?
Summers
If I copy a detail and paste it on a different page, then modify the detail, X9 continues to update the original detail with my changes (as well as the copied detail).
If I open a detail from one page, send it to another page, then modify the detail, the result is the same--X9 still modifies my original detail--which I want to stay the same.
How do I copy a detail from one page to another (for the purpose of modifying the detail) in a manner that breaks the connection to the original detail?
You make a copy of the detail so you then have two separate details. I commonly do this in a CAD Detail window, make a copy so I then have two identical details, the second one I can then alter because it has a different name. Then I send them both to layout from the .plan file placing them wherever I want.
A digital copy of a AD detail is merely another instance of the same detail, that is why I make two copies first, then alter the second copy as it is now a separate object with a different name, digitally speaking.
