missing part of pattern in 3d
natmar
On 1/17/2018 at 10:51 AM, natmar said:
i check my wall layer component and also change the tickness of exterior material.........did'nt change :(
Try Changing the Roofing material in the Structure Tab to 1/4-3/8" thickness  not the Wall Material Thickness...
*** edit for Others.... you have to make the change manually for each roof plane,
      or use the Edit All Roof Planes tool; making the change in the Defaults will not modify existing roofs.
Changing the roof shingle thickness to 1/4" fixes the problem for me. Keep in mind that you have to make the change manually for each roof plane, or use the Edit All Roof Planes tool; making the change in the Defaults will not modify existing roofs.
