jonboy Posted January 11, 2018 Share Posted January 11, 2018 X10 Trying to build a foundation wall that has 4 cr of 12" block with the last or top course being 6" and centered in the middle of the 12" block... I built a wall using a poly wall with the top course 6" centered on the 12" block but then in 3D the concrete floors only builds to the 12" block leaving a gap. Anyone have any ideas....this is what I am trying to do thanks Link to comment Share on other sites More sharing options...
jonboy Posted January 11, 2018 Author Share Posted January 11, 2018 Thanks for looking at this Link to comment Share on other sites More sharing options...
justmejerry Posted January 11, 2018 Share Posted January 11, 2018 Not sure if this is what you're after but should be no problem with autobuild except for the pony wall. Draw the pony wall in last. as long as you have your defaults set up correct should be no problem. Only edit I did was the chamfers on the floor slabs. If you post your plan, you will have a fix quickly. Link to comment Share on other sites More sharing options...
jonboy Posted January 11, 2018 Author Share Posted January 11, 2018 Had to get the file small enough zip_plan.zip Link to comment Share on other sites More sharing options...
jonboy Posted January 11, 2018 Author Share Posted January 11, 2018 I would like to thank both of you for your input ... BUT I must have something wrong in my defaults ... Solver I followed your instructions to the T.. started with foundation default then once I have the foundation completed I go back and change a wall to the pony wall and I still get the same .. coming up short with the slab ... so that said I am thinking something in my defaults I am doing wrong .. thanks for the help Link to comment Share on other sites More sharing options...
Kbird1 Posted January 11, 2018 Share Posted January 11, 2018 Did you delete the foundation and start over? I have found in the past that CA "remembers" settings which can play havoc trying to change things mid project.... try it in a Copy of your good plan perhaps..... Link to comment Share on other sites More sharing options...
javatom Posted January 11, 2018 Share Posted January 11, 2018 Remember that an auto detailed section view does not update. It may be right but you are looking at previously generated auto fill patterns. Link to comment Share on other sites More sharing options...
jonboy Posted January 12, 2018 Author Share Posted January 12, 2018 Finally got it to work .... thanks everyone Link to comment Share on other sites More sharing options...
