Robboulton Posted January 5, 2018 Share Posted January 5, 2018 I need to create a twin gable roof like a capital M. These two gables then intersect the main roof at 90 degrees. Is there a simple way to do this? Sorry if this is easy but I am quite new to Chief. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 5, 2018 Share Posted January 5, 2018 That depends upon the geometry of your floor plan as to whether or not this can be preset and then auto-built. Manually you just do it manually by direct manipulation. DJP Link to comment Share on other sites More sharing options...
Robboulton Posted January 5, 2018 Author Share Posted January 5, 2018 The specific file is attached now, if you look you'll see the rear roof is way too high. I though i could split it into a double apex roof to make it work better. Any help appreciated. Thanks 20180101 - Larger Design With Furniture.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted January 5, 2018 Share Posted January 5, 2018 I'd think about other Designs as I think looking at Eric's Pic, in heavy rainfall you will end up with a Waterfall in front of that Window , onto the Patio below. Either use a lower pitch like 25° from each side ( not 45°) , or maybe even a 25° Hip Roof with a 45°pitch to match the current house on current gable wall to reduce facade height or perhaps even a Shed Dormer style Roof at 15-18° tied into the existing Roof ? M. Link to comment Share on other sites More sharing options...
