40mstew Posted January 3, 2018 Share Posted January 3, 2018 Never had a problem with this before. If I draw a wall that ends at the front of the shower, the end wall shows a stud with no drywall. I really don't want to have to draw a polyline solid, rename it on the layer, and paint it. Frustrating because I didn't have this problem just last week. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 3, 2018 Share Posted January 3, 2018 If the drywall is part of the main layer of the wall that could possibly happen but there is limited information here for anything more than a guess. Link to comment Share on other sites More sharing options...
40mstew Posted January 3, 2018 Author Share Posted January 3, 2018 Here is the plan. See the attached. Stewart_2018.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 3, 2018 Share Posted January 3, 2018 Your problem is in your wall definition. Chief only wraps the outermost layer around the end of your wall. Your outermost layer is 0" thick so that's what you're seeing. Link to comment Share on other sites More sharing options...
40mstew Posted January 3, 2018 Author Share Posted January 3, 2018 Yep, it worked!! Greatly appreciated!! You guys are Awesome! Link to comment Share on other sites More sharing options...
CharlesVolz Posted January 3, 2018 Share Posted January 3, 2018 (edited) The wall's outside layer wraps the end (the paint with zero thickness in this case), not the drywall (unless it is the outside layer). So either 1) make the drywall the outside layer and change the drywall color as desired or 2) give the paint layer a 1/32" thickness. [EDIT] What they said. I think Chief should fix this so that everything wraps the main layer. Edited January 3, 2018 by CharlesVolz Link to comment Share on other sites More sharing options...
Chopsaw Posted January 3, 2018 Share Posted January 3, 2018 So that kinda blows the theory of not painting walls then doesn't it. What is the proper procedure ? As most drywallers do not leave exposed studs for the painters. Link to comment Share on other sites More sharing options...
40mstew Posted January 3, 2018 Author Share Posted January 3, 2018 I would think that you would have to give the drywall a color??? My two cents.... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 3, 2018 Share Posted January 3, 2018 29 minutes ago, Chopsaw said: What is the proper procedure ? As most drywallers do not leave exposed studs for the painters. Lots of ways to handle it... You can paint the walls (could be done with "Blend Colors With Materials" toggled off or on depending on the situation). I do this all the time. When I hear people tell new Chiefers "DON'T DO THIS" I think they're doing a disservice. Better to teach people how to use the tools properly than to tell them not to use them at all. You can create a new "Drywall" or "Siding" material for each color you'll be using. This new material can then be applied using paint can, or by changing material in room definition, or by changing material in wall definition, or by changing material in wall type definition...all of which have their upsides and downsides. Again, you can optionally simply paint your material with "Blend" toggled on which will automatically create a new material for you. You can use a Wall Material Region. You can apply a Wall Covering. In the end I don't think there is any right answer. Just learn how the tools work, and then decide what works best for you and your particular situation. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 3, 2018 Share Posted January 3, 2018 Thanks guys, That is a real help and it looks like if people want to use the wall definition for paint layers the suggestion Charles made has good merit. 34 minutes ago, CharlesVolz said: I think Chief should fix this so that everything wraps the main layer. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 4, 2018 Share Posted January 4, 2018 4 minutes ago, Chopsaw said: ...the suggestion Charles made has good merit. Agreed...at least as an option. Like so many other good suggestions, it needs to actually be posted in a usable form in the suggestion forum or sent in to Chief if we want Chief to even consider it. Otherwise, I can pretty well guarantee its never ever gonna happen. Link to comment Share on other sites More sharing options...
CharlesVolz Posted January 4, 2018 Share Posted January 4, 2018 I will submit it. Link to comment Share on other sites More sharing options...
