Rachael_Venue
Elevation Markers
Hi All,
Can someone help me resize the elevation markers on my floor plan?  When I insert an elevation on my layout page with macros, the elevation marker will indicate the elevation number and page number.  Unfortunately, it adjusts the size of the marker to accommodate the additional text, but it becomes too large for my floor plan and basically takes over the entire floor plan.  Not to mention, I can't insert them where I want, without them overlapping each other, and therefore not taking the view that i want to show in my elevation.  I can't seem to figure out how to resize the markers to the appropriate size for the plan (1/2" Scale Bathroom plan).  Does anyone have any tips/suggestions that I can use?  Thank you!
Bathroom Plan.pdf
Their size is controlled by the Text Style used by the Cameras Layer.  Accessible through Active Layer Display Options when selected.
Really - Thank you so much!!  I can't believe it was that easy.  I have tried searching for the answer, but nothing comes up and I tried changing the text style in the defaults, but nothing worked.  This is so helpful!!!  =))
    27825
    ChiefDallas
    ChiefDallas
  • Similar Content
    • By divreig
      I think I am missing something. I want the "Text Below Line" on my Elevation Camera Labels/callouts to show the sheet number. And make this the default. Does any one know how?
    • By AndrewCass88
      Hello I'm having an issue w/ my elevation. How do you get it to update automatically what layout page it is on?
    • By Aamir77
      Good day, all of you.
      Need your kind attention to finalize a front elevation of a house. The plan is attached Aamir77_gutted_MHD_Rev1.zip to the post. Please confer me a little segment of your precious time. I have been up to 3 types of front elevation which are also attached herewith as pictures. Thanks in advance.
    • By expodesigngroup
      Anybody know why these random horizontal lines suddenly appeared in my elevations?
      Not sure what I did, but just appeared.  I've tried selecting the lines, and locating in different parts of the elevations and plan to figure out what it is and how to remove.  It's totally inaccessible.
    • By Sweeney
      Hi all,
      Wondering if there is a way to set a benchmark elevation to "0"? I recently finished up a set of condocs and today the client wanted to change the basement stem wall from 9' to 12'.  Instead of adjusting each room from the basement up, I would rather drop the basement down to account for the extra 3' and then reset that -3' floor change to the "0" benchmark. This would help in story pole dimensions and setting heights of all sorts of imported Sketchup pieces.
      Thanks in advance,
      Austin
