Baseboard under Toekick
Rich_Winsor
1 hour ago, Rich_Winsor said:
It's a little thing but it has been bugging me no end.
How do you make the baseboard continue under
the toe kick of a base cabinet?
If you make a Room Molding Polyline and then break the RMPL at the edge of the Cabinet Kick , you can then select the portion upto the cabinet on the half wall (click right on the edit handle is easiest)  and uncheck "no molding on this edge" , it will fill back in.
It maybe helpful to drop a cad line in at the kick distance in from the cabinet face so you can accurately cut the RMPL.
