Rich_Winsor
Baseboard under Toekick
It's a little thing but it has been bugging me no end.
How do you make the baseboard continue under
the toe kick of a base cabinet?
If you make a Room Molding Polyline and then break the RMPL at the edge of the Cabinet Kick , you can then select the portion upto the cabinet on the half wall (click right on the edit handle is easiest)  and uncheck "no molding on this edge" , it will fill back in.
It maybe helpful to drop a cad line in at the kick distance in from the cabinet face so you can accurately cut the RMPL.
You can just add it under mouldings. It will place it against toe kick if you select 0" to bottom.
Just re-read your question. If you want to just patch the small section then do as Mick suggests.
    27825
    ChiefDallas
    ChiefDallas
